volvo 850 heat vent not working
Old Oct 11, 2009 | 07:06 PM
chadman551's Avatar
Default volvo 850 heat vent not working
My 1995 volvo 850's heat doesnt work on the passenger side, the heat works fine on the driver side, but on the passenger side no air comes out of the upper vents, and i think it might be clogged cause some stuff came out of the driver side vents, like dirt and stuff, and could someone tell me how to unclog the vents? and the cabin air filter has nothing in it.
Old Oct 11, 2009 | 07:29 PM
Are the vents on that side closed?
Old Oct 11, 2009 | 08:05 PM
chadman551's Avatar
no they are all open and the divers side world fine
Old Oct 11, 2009 | 08:12 PM
Is it MCC or ECC?
Old Oct 11, 2009 | 08:19 PM
chadman551's Avatar
it is ECC
Old Oct 11, 2009 | 08:20 PM
chadman551's Avatar
i think
Old Oct 11, 2009 | 08:21 PM
Easiest way check is do you have colors for temps or numbers?
Colors=MCC
Numbers=ECC
Old Oct 11, 2009 | 08:23 PM
chadman551's Avatar
ok then it is ecc then
Old Oct 11, 2009 | 08:29 PM
Maybe the motor for the passenger side is not working.
Does the controls still work for defrost and floor vents?
If not then maybe the controller is bad.
Old Oct 11, 2009 | 08:36 PM
chadman551's Avatar
the defrost for the passanger side and the floor for the passenger both work fine, just the face vents on the passenger side dont work
Old Oct 11, 2009 | 08:46 PM
There should be 2 blend motors on the passenger side. It might be one of them. I do not have the diagram handy on which one is which.
Sean Berger
Nov 16, 2017 08:58 PM
rspi
Mar 22, 2014 09:32 PM
packetfire
2001-2013 model year V70
Feb 25, 2014 11:09 PM
x-angel
Nov 13, 2013 06:00 PM
floryed
Feb 13, 2007 10:24 AM
