Timing belt, vvt, code p1014
Old Aug 18, 2010 | 11:49 AM
arthurdentx's Avatar
Default Timing belt, vvt, code p1014
Hi everyone. Hopefully I find some help here.
I have a 2001 V40 2.0 turbo, and recently I renewed the cylinder head. All worked fine, the car runs ok, but: The MIL is lit, and it tells me code p1014, which means CMP Sensor/CKP Sensor Signals Not Compatible.
Since I made sure the wheels are all on the right positions, all marks align with their counterparts in position 12 oīclock, I guess I must have put the wheel with the vtt in the wrong position. I did never remove the wheel from the camshaft.
Will it be possible to loosen the timing belt, put the vtt back into the proper position and fix it back? and which will be the proper position?
Iīll be thankful for any hint.
(please excuse me if my english is not perfect, itīs not my native language )
Thomas
edit: I read some other threads about the subject in the meantime. Still, Iīm not really sure if I got it right. What I suppose is, that, when I put the new belt on, the vvt pulley showed the right position in terms of the marks, but the cam itself was turned a little. When the belt is off, you can turn the vvt a little without moving the cam, so, how do I find the right position? Somewhere I read itīs about 1.5 teeth to the left, somewhere I read itīs to the right, so, Iīm kinda confused.
Old Aug 19, 2010 | 02:26 PM
thx for not answering... got it fixed alrdy.
Old Jan 23, 2012 | 11:24 PM
AndreK's Avatar
Hi guys,
I know this is an old thread but does someone know what's the easiest way to fix this 'vvt home position' problem?
When the cams are locked at the back, to which side am I supposed to turn the timing gear on the vvt unit? Clockwise or anti-clockwise?
Thx
André
Old Jan 24, 2012 | 01:37 PM
turn until the marks on the wheel and on the plastic cover match, overturn clockwise about 90°, turn back until the marks match again. Then mount the tool to block the camshafts (see attachement; u donīt need to buy the tool in case u donīt have it alrdy)
(I sent u a pm, got some more instructions that I cannot post here due to file size)
(btw... why is no1 answering here? is this forum dead?)
Attached Thumbnails Timing belt, vvt, code p1014-vvttimimgprocedure004qz9.jpg
Old Jan 25, 2012 | 10:19 PM
AndreK's Avatar
Problem solved!
Thanks again my friend!
It's very much appreciated.
Old Jan 26, 2012 | 03:14 AM
Glad to hear that. Engine light stays off?
If u have any other trouble with ur volvo (hopefully not), donīt hesitate to poke me.
This forum indeed seems to be kinda dead, but in the links I sent u per email, u might find some better sources I guess.
Old Jan 31, 2012 | 04:13 AM
AndreK's Avatar
Sorry! Double post :-)
Old Jan 31, 2012 | 04:18 AM
AndreK's Avatar
Hi again,
Yes the 'check engine light' didn't come back on again but there's still another issue - when the car is started from cold it wil begin to overfuel/smoke just before it reaches normal engine temperature and then after normal temperature has been reached, it stops smoking.
Any ideas what could cause this?
Old Feb 1, 2012 | 03:21 AM
Originally Posted by AndreK
Hi again,
Some smoke with cold engine is quite normal, since u can see the steam of the water falling out when fuel is burned.
Other possibilities: Temperature sensor showing too low values, making the ecu overfuel, mass airflow sensor faulty.
Old Feb 8, 2014 | 01:41 PM
vppaul123456's Avatar
Hi arthurdentx, can send me the "some more instructions" file you sent the other poster? Thanks
Old Feb 8, 2014 | 01:42 PM
Hi arthurdentx, can you send me the "some more instructions" file you sent the other poster? Thanks
Old Feb 12, 2014 | 02:37 PM
Hello. Would you be so kind to email me the information that you gave AndreK? Thanks.
Old Feb 27, 2014 | 07:30 PM
Toyznstuff's Avatar
HELP!!! I am trying to find the Camshaft Position Sensor on a 2000 V40 w/ 1.9 Turbo.
I have Haynes Manual (Chilton is not available) & where it seems it should be, same side as the battery & there is a round plug there about 2" dia. (?) & bolt holes, 2 about 3/16"-1/4" (?), but No Sensor or wires. Any images/pics would help. Thanks!
Old Apr 26, 2014 | 10:44 PM
SoK66's Avatar
It's at the end of the exhaust cam, which is the one closest to the firewall. Screws onto the cylinder head & engages with the exhaust cam.
Old Oct 25, 2019 | 08:18 PM
Robert Musgrove's Avatar
Would you please send me this info as well?
kzabrisk
Sep 23, 2015 12:22 PM
SoK66
May 2, 2014 05:39 PM
Hopper
1998-2000 model year V70
Sep 15, 2012 10:48 PM
russellsv40
Jun 2, 2011 12:02 PM
alex440
Dec 11, 2009 08:47 PM
