Sponsored by:
Sponsored by: DashLynx
My Hazard light! 2004 s60
Old 03-16-2017, 06:49 PM
Dave11's Avatar
Default My Hazard light! 2004 s60
My hazard light switch does not work. When I connect it they blink but do not shut off. When I disconnect it they stay on until I reconnect it. Is it the switch or something else?
Old 03-16-2017, 06:54 PM
ES6T's Avatar
Probably the switch
Old 03-16-2017, 07:31 PM
Dave11's Avatar
Is the switch supposed to click?
Old 03-16-2017, 07:41 PM
ES6T's Avatar
As it flashes? Yes, you can hear it click as it flashes.
Old 03-16-2017, 07:43 PM
Dave11's Avatar
No, does the switch click when depressed?
Old 03-16-2017, 08:04 PM
ES6T's Avatar
Actually no, it doesn't click when turning on or when flashing.
Old 03-16-2017, 08:20 PM
Dave11's Avatar
It has 3 wires going into the harness. I have tried 2 switches. Been working on this car and this is my last issue. Very frustrating. I plug in the switch and it turns on. I remove the switch and it continues to blink. Then when I reconnect the switch it turns off. Urgg!!!
Old 03-16-2017, 09:19 PM
ES6T's Avatar
Could be a CEM, too. I'd need to check with the wiring diagrams.
Old 03-16-2017, 09:26 PM
Dave11's Avatar
Any help is much appreciated. Thank you.
Old 03-17-2017, 10:50 AM
ES6T's Avatar
Are the switches new or used?
Do the turn signals work?
Old 03-17-2017, 10:53 AM
Dave11's Avatar
The first switch came with the car. The second I purchased on ebay. The signals work as they should.
Old 03-17-2017, 11:10 AM
ES6T's Avatar
So they are both used?
Old 03-17-2017, 11:20 AM
Dave11's Avatar
Yes they are.
Old 03-17-2017, 11:46 AM
ES6T's Avatar
I would try a new one. The only other thing is the CEM, which would be expensive.
The black wire is ground. The yellow wire should have battery voltage when the button is released and low voltage when pressed. The yellow and white wire is for the lamp.
Old 03-24-2017, 03:14 PM
Dave11's Avatar
Sorry for the delay. I just received a new switch from Volvo and the same problem is happening. I plug the switch in and the hazard lights start flashing. When I unplug the switch they stay on. When I reconnect it they turn off. So depressing.
Old 03-24-2017, 03:22 PM
Smith Volvo's Avatar
Banned
Here is your wiring diagram - looks like it might be the CEM?
File Type: pdf
denstill
01-10-2022 07:55 PM
marc sanders
08-31-2015 11:15 PM
Jonboy
2001-2013 model year V70
04-17-2013 11:12 PM
Amelia
07-17-2009 07:16 PM
volvro18
10-13-2008 07:57 AM
Quick Reply: My Hazard light! 2004 s60
