98 V70 AWD, intermittent shift lock problems
Old 01-04-2007, 12:06 AM
tcrossley's Avatar
Default 98 V70 AWD, intermittent shift lock problems
Hello All,
Happy new year.
For some time now my V70 has intermittently not allowed shifting out of park. I have taken the console/shifter apart twice now, but nothing seems obvious. I searched these forums and found some good info, but the intermittent nature of my symptom has proven difficult to diagnose. The mechanical overide button always works (of course).
Microswitch tests ok consistantly, I don't think that's the issue
Solenoid tests ok (continuity)
Brake lights always come on, even when shift lock does not disengage, brake pedal switch appears ok
I have not tested the ignition switch, jiggling it to get the lock to disengage is unsuccessful.
Any suggestions from you 'volvo yodas' out there?
Thanks,
Todd
Old 01-04-2007, 12:22 AM
Default RE: 98 V70 AWD, intermittent shift lock problems
I would say the Micro switch.
They are common to go bad.
You could bypass the switch. But the draw back is that you will hear the soleniod click everytime you hit the brakes.
Old 03-11-2007, 01:59 PM
ubergeek's Avatar
We just had a tech session on various problems and this came up. The real problem is the shifter **** itself. Run your finger along the bottom edge of the button on the shifter. if there are any breaks or gaps replace it. Part costs about $70.Vovlo pn:
91813561Gear lever **** standard
» 9181357 REPL 1PCS 9192681-6.
» 9192682 (9181358)
» 30618154 (30899151)
91813571SPGear lever **** walnut, black4
91926811Knob walnut, black6
91926821Knob walnut, red6
306181541Gear lever **** red imitation wood5
91837871Gear lever **** grey leather
Old 09-21-2010, 07:48 PM
Craigbell's Avatar
My 98 V70 has the same problem. When I hit the over ride to get it out of park then my lights and signals do not work so I have to turn the car off and restart until it comes out of park. Is this the shifter **** as well and not the micro switch?
Nontechie
10-24-2008 11:55 AM
H20Gguy
09-17-2008 12:58 AM
mparker
08-31-2008 08:02 AM
Quick Reply: 98 V70 AWD, intermittent shift lock problems
