Car sputtering with left turn signal
Old Aug 21, 2022 | 04:38 PM
axaaxa123's Avatar
Question Car sputtering with left turn signal
Hello all,
I own a 1998 Volvo v70 with about 219,000 miles, and recently when I signal left, I find that my car begins to sputter when I'm at higher speeds (45mph+). This makes it hard to merge, nor does it feel nice to drive, because the car will start jerking/sputtering instead of continuing to drive smoothly as it had been doing before. Does anyone have any ideas about what might be causing this? I saw a forum a little while ago that suggested fuel injectors but I haven't found it since.
Thank you!
Old Feb 6, 2023 | 07:36 AM
Thaddeus_the_Bold's Avatar
Volvos are prone to weird behavior if they have any dirty grounds. I had a 740 that would outright die if I flashed the high beams. Cleaning up the grounds fixed it.
Go under the hood and wherever a ground point is, clean it up so it's shiny and tight. Just clean every one you can. See if the Fuel injectors have ground wires to the engine block; clean those. Then also make sure the ground wires for the lights- tail and forward -- are also clean and shiny. Hose them down with WD40 when they are all clean. Then let us know if the behavior changes.
SlikRick
Nov 12, 2017 08:20 AM
S70driver
Jan 11, 2012 10:17 AM
Newport_j
Aug 9, 2011 09:16 PM
my960
Sep 8, 2010 08:40 PM
Alexander
Aug 4, 2005 09:10 PM
