Need cam sensor plug pin order
Old Oct 15, 2020 | 01:29 PM
CSC's Avatar
CSC
Default Need cam sensor plug pin order
1999 V70 mk1 petrol.
Does anyone know the order of the three pins in the cam sensor connector plug on the ecu side of the plug (the side that goes to the ecu)
In testing instructions the pins are called pin1 pin2 pin3 but it does not make clear which pin is which out of the three pins in the plug. When looking into the plug is the pin number order from left to right 123? or is the order from right to left (which would physically place them across the plug as 321) or is it another combination?
I can only be sure of the test results once I know I'm testing correctly from having identified the correct number order and position of the three pins in the connector. Advice greatly appreciated.
JackReigh
May 9, 2020 08:46 AM
Sufarry
Jul 30, 2018 11:24 AM
darabiford
2001-2013 model year V70
Mar 27, 2016 06:46 PM
jmcconnell
Jun 24, 2011 01:57 AM
arrow
Feb 26, 2011 03:33 PM
