Removing window switch
Old Oct 12, 2013 | 10:45 PM
Grey Bearded One's Avatar
Default Removing window switch
The mirror joystick on my 2001 V70 is broken so I figured that I'd get one at a junkyard.
I started prying at the switch module in my door and it did not want to come out easily. I didn't want to destroy the upholstery on the door handle so I stopped prying.
Is there a trick to getting the switch out?
Thanks.
Old Oct 12, 2013 | 11:41 PM
damien360's Avatar
you have to remove the door panel in order to remove the switch. there is a torx 25 that you have to remove inside the door panel.
Old Oct 13, 2013 | 07:45 AM
Can they make things any more complicated?
I found an online video about removing the window switch from a 2000 V70 and it just popped out. I figured that my car would be the same since in every car that I've ever had with window switches in the door they just popped out.
That just seems like some really bad design work.
Okay, what are the tricks to removing the door panel?
Found a Youtube video on removing the door panel. I never would have figured that one out.
daduke
Mar 21, 2014 12:26 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
stecz
Dec 31, 2007 05:40 PM
jguerra3235
May 27, 2007 06:43 PM
