2010 xc70 p045500
Old Apr 15, 2019 | 03:19 PM
Jake Dziekan's Avatar
Default 2010 xc70 p045500
I plugged in my scanner to check for a cyl 6 misfire p030600 and found this code as well and I cannot even get it to clear. There is no engine light either looking for help or ideas thanks
Old Apr 18, 2019 | 05:30 PM
Volvo DTC ECM-P045500
Make:
Volvo
Code:
ECM-P045500
Definition:
Evaporative Emission System Leak Detected (Gross Leak/No Flow).
The engine control module (ECM) checks for leaks in the fuel system by measuring the current consumption of the leakage diagnosis pump when pressure is applied. If the current consumption measured under pressure does not change in a specific way or a certain pressure is not obtained in the system within a reasonable amount of time, the control module assesses this as a large leak (leak larger than 1.0 mm) from the fuel system. See Design and Function for more information. The diagnostic trouble code can be diagnosed when leakage diagnosis is running.
Cause:
  • Tank cap not properly tightened or not in place.
  • Leaking tank, filler pipe, tank cap, canister, EVAP valve or lines between these components.
Mountainduc
Aug 18, 2018 08:49 AM
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
drenman
2001-2013 model year V70
Jul 20, 2015 08:08 PM
parksjm
Sep 27, 2010 07:54 PM
jsj_297
May 13, 2008 03:22 PM
