Heater fan intermittant - after huge $$$$$
Old May 20, 2024 | 06:54 AM
bookwomen's Avatar
Default Heater fan intermittant - after huge $$$$$
Will be dropping the car off again at dealership this morning to continue troubleshooting cause of:
  1. From cold start, Climate control allows fan to come on for 2-3 seconds, turns off, then turns on again for 2-3 seconds, then goes off for a longer period, then comes on after a random longer time duration
  2. Internal valves, doors and the like all seem to be functioning with switching between heat and cold. Fan seems to be at low speed idle - I can feel cold or hot coming from vents
  3. The issue seems to be with the fan not being commanded to turn on and off properly.
  4. To date, $1258.84 for fan replacement. Reported “climate controls now functioning properly” was incorrect, did NOT fix issue as we agreed.
  5. Too, date, $445.23 replacement of the climate control module did not fix the issue.
The XC70 was in production for many years, and there are many aging vehicles out there likely having this same issue. I googled this and there was a lot out there, but beyond my DIY skills, hence, I brought th car to the dealership where you have all the diagnostic equipment and skilled techs.
Hoping someone can help !
thank you
Louise Roy
May 16, 2013 06:49 AM
jmanakyan
Sep 10, 2010 08:59 PM
boxpin
Nov 11, 2009 07:44 PM
Eli Delta
May 14, 2009 12:07 PM
AshevilleXC70
Aug 21, 2005 01:38 PM
