Flat Tire
Old Jul 9, 2009 | 08:09 PM
Ma$60's Avatar
Default Flat Tire
I accidentally pulled the valve stem out of my S60 trying to check tire pressure. Do I need to get a dealer replacement?
Old Jul 10, 2009 | 09:13 PM
Can you screw it back in? Other than that, I'm not sure. A valve stem should be a valve stem.
Old Jul 10, 2009 | 09:42 PM
01_fast_ride's Avatar
Any tire shop can replace it. Some places wont charge for it.
Old Jul 11, 2009 | 11:10 AM
malaka's Avatar
Just wait until we all have federally-mandated TPS (tire pressure sensors) because of those individuals unable to check their tire pressure. Somehow, I think there's a simple gauge, analog or digital (take your pick) to perform this task. Then again, some might choose the eyeball and thumb pressure method if the gauge method is too troublesome.
The original idea was probably good for "run flat" tires. But, of course, now they'll become some added mandatory electronic geegaws which will wear out and need to be replaced after giving misleading readings to a driver with a lighted alert on the dash. Remember, the sensor is inside the tire, subject to huge temp variations, and of course, many millions of revolutions over its lifetime at different speeds and centrifugal forces.
Old Jul 11, 2009 | 10:37 PM
Ma$60's Avatar
$125 dollar!! That's how much it cost at Volvo to replace 1 stem. Not warranteed because not original valve cover.
rspi
Apr 3, 2012 07:51 PM
wzlee
May 14, 2009 07:54 AM
fredgold52
Jan 31, 2008 11:50 AM
NadineInTexas
Jun 15, 2007 10:59 AM
jetsfever4ever
Dec 20, 2006 03:05 AM
