Power Loss S40
Old Mar 16, 2009 | 06:53 AM
numseven's Avatar
Default Power Loss S40
I have a Volvo S40, which when I drive has developed a power loss. However the engine is still revving at the same rate.
I have had the exhaust done (but not the cat converter) and the petrol tank breather has been done as well. Do not know where to go now, as I have been spending more money which has not worked so far. This is also not a continual problem, and can kick in for a second or minutes.
Could it be electronic?
Thanks to anyone whom can give me something to look at.
Old Mar 16, 2009 | 02:41 PM
BlazeS70's Avatar
Do you have a Check Engine light on?
Old Mar 17, 2009 | 04:27 AM
numseven's Avatar
Default No Lights Comne On
Absolutely no lights come on - it is just this sudden loss of power.
Old Mar 17, 2009 | 06:01 AM
JPN's Avatar
JPN
The U.S models are affected by following recalls (2004 and up):
http://www.autobuyguide.com/2004/12-...lls/index.html
What is your model year and accumulated mileage/kilometers? Also, how's the transmission performance? When was the last full tune-up? Was the exhaust repair done right with no blockage? Blocked exhaust can prevent the can from going above certain speed but the engine could rev under no load in some cases.
If the problem is within the engine/tranny electronic control, it usually turns the CEL (Lambda) on but sometimes they don't. If you can afford to, you may wish to have fault code(s) read by Volvo garage.
With limited info, this is the best I can do. Moderator Tech & other experts would be able to give you more accurate diagnosis.
JPN
Old Mar 18, 2009 | 04:37 AM
numseven's Avatar
Default Thanks
Thanks for the info.
I think a diagnostic test is the thing to go for now.
I hoped it would be sheaper but hey, that is owning a car for you.
Thanks once more
Ian
Wesley brown
Oct 7, 2014 10:12 AM
travislyle
May 10, 2010 11:32 AM
billabongct
Dec 13, 2008 09:17 PM
Fantasia
Dec 9, 2007 02:01 PM
tvmicrowave2002
Sep 12, 2006 05:33 AM
