Transmission Fun Ness....
Old Oct 3, 2008 | 02:30 PM
  #41
Default RE: Transmission Fun Ness....
Glad it is for the most part fixed.
Old Oct 3, 2008 | 04:14 PM
  #42
ShaginWagon's Avatar
it lives !!!!!!!!!!!!!!!!
hooray !!!!!!!!!!
Old Oct 8, 2008 | 12:17 AM
  #43
gordon368's Avatar
lol thanks!
just out of curiousity, sometimes i like to downshift the car2 to 1, and I dont get a kick down. it just downshifts and doesnt slow the car down like it use too. Some times I like to downshift 2 to 1 just to take a turn quick and drop back using the kick down feature and well it didnt do it today.
Old Oct 8, 2008 | 07:30 AM
  #44
Maybe there is transmission error codes?
Old Oct 8, 2008 | 08:08 PM
  #45
gordon368's Avatar
surprisingly from my scanner no, but most likely my scanner canr read them right? Could it be the Transmission fluid being low could do it?when the car was driven for 2 hrs i checked it and the fluid was only at the cold level.
Old Oct 8, 2008 | 08:58 PM
  #46
Maybe these tranny's are really picky.
Also what year is the car? (To many cars on here to remember)
Old Oct 8, 2008 | 11:03 PM
  #47
gordon368's Avatar
2001 s80 t6 . Its surging again (1000-3000 rmps), no stalls, no codes (which is the weird part). since they cleaned my ETM its been Driving ALOT better, but do you think I might need a new ETM? Is not having that downshifting kick back feeling a bad thing?
also did I hear right that these cars cannot have a wireless start installed in them?
Old Oct 9, 2008 | 07:19 AM
  #48
Try this to see if the ECM or TCM have codes. Press in the read button and hold it. Then while holding it press and release the rear foglight switch 3 times fast. Then release the read and in the window it will say something like checking for DTC's stored in car. Then press the read button to go through the module and see what modules have codes in them. It only tells you what module have codes. It will not give codes.
Remote starts can be installed but it is a major pain to get it installed and working.
Old Mar 1, 2011 | 08:42 AM
  #49
schannell's Avatar
Default Hissing noise after transmission rebuild
Where is that metal collar supposed to be located? I just had the tranny rebuilt on my XC90 (2004 T6), and it was making the hissing noise described by gordon386, and the steering wheel was squeaking. I lubricated the steering shaft where it goes into the rubber boot at the floor board which stopped the squeaking, and I noticed a metal collar that fits around the neck of the boot. It's not attached, it just sits in place. Is that supposed to be there, or did it fall out of place from higher up on the shaft? Was wondering how the metal collar was related to the hissing noise. I would greatly appreciate your feedback.
Originally Posted by tech
The tranny does need to relearn. Also look where the steering shaft goes through the floor. There is a metal collar that usually comes out and will make the hissing noise. Lastly have the engine mounts checked.
Old Mar 2, 2011 | 12:28 PM
  #50
ibanez958's Avatar
it sounds like u have more then 1 problems. u need to isolate the problems first before u diagnosis the problem. first the transmission does need to be learn, but not by just normal driving. u need to hood up to a volvo computer (Vida) which there is a function for tcm reset adaptation, there is a procedure for that & is kind of complicated. Also u need to check it the TCM software upgraded or not. also did they used OEM trans. fluid, it does make a different. The engine stall, I suggest u get a Vida to scan it, at least get a proper diagnosis before u start to spend any money.
Shaun Oriold1
Oct 11, 2006 01:18 AM
druid
Aug 24, 2006 11:15 AM
jdhore1
Jul 6, 2006 07:31 PM
colgate41
May 19, 2006 12:47 AM
matthewensey
Sep 22, 2005 10:34 PM
