Why is my 940T cold??
Old Jan 31, 2010 | 10:06 PM
rooster11's Avatar
Question Why is my 940T cold??
During winter driving conditions, even if I let the '94 940T warm up, temp gage in mid range, heat warm, once I begin to drive it cools off so much the heater feels like a cheap heat pump blowing cold air. What is the solution? Thanks, rooster
Old Feb 1, 2010 | 01:24 AM
Typhoon's Avatar
Check your thermostat for correct operation.
Regards, Andrew.
Old Feb 1, 2010 | 10:18 PM
rooster11's Avatar
Exclamation thank you typhoon
Thanks, Andrew, I will change thermostat in the am. Tonight I popped the hood to take a look and was shocked to find the engin HOT, glowing red on exhaust manifold. !!! But still no heat. I now understand this could mean water pump if after I test and change thermostat. Any thoughts? thx, Colin
Old Feb 2, 2010 | 03:43 AM
Typhoon's Avatar
Have you got coolant? Glowing exhaust manifold can be overly rich fuel mixture or retarded timing, that will cause an engine to run cold too.
Regards, Andrew.
Old Feb 2, 2010 | 10:29 PM
rooster11's Avatar
Smile Thanks,andrew
Yea, I have coolant, and when I took out the thermostat, it was visibly damaged. Put the new one in, fan working, water circulating, normal engin temp, and the Heat works so my son no longer complains returning from skiing. Also changed the plugs, and pleased to note that the old ones looked really clean, no oil. I will check the exhaust manifold again at night, but think thermostat fixed everything. Thank you again, Colin
VOLVO15
Sep 21, 2009 04:51 PM
jdseattle
Dec 31, 2008 08:04 AM
MrBusterGuy
Jul 16, 2006 09:50 PM
evyllp
Nov 30, 2004 09:58 PM
stever
Nov 29, 2004 10:57 PM
