1990 1990 740 Volvo / Idles fine, dies when given gas
Old Nov 16, 2014 | 01:57 PM
mattem's Avatar
Default 1990 1990 740 Volvo / Idles fine, dies when given gas
Hello everyone - New on the seen, live in southern California and the wind is blowing 30 - 50mph - Yuck. My daughter has a 1990 740 Volvo that recently won't start. We can start it with starting fluid and it will idle fine, but as soon as you give some gas it dies. We have replaced the plugs, cleaned the mass airflow sensor, checked fuse #1 that was recommended to reset something with the engine, but nothing has changed - any ideas would be appreciated - Thanks
Old Nov 16, 2014 | 05:29 PM
air leaks in the air path between the MAF and the intake manifold ?
since it starts with starter fluid, its probably not spark/ignition.
cleaning MAF's rarely does any good, and often can make them worse. I'd find another MAF from a working 940/240 (1989+ non-turbo, or 1990+ turbo) and swap them, see if that fixes it, if so, you need a new MAF...
Old May 13, 2020 | 11:23 PM
2VolvosMan's Avatar
Exclamation
[QUOTE=mattem;400206]Hello everyone - New on the seen, live in southern California and the wind is blowing 30 - 50mph - Yuck. My daughter has a 1990 740 Volvo that recently won't start. We can start it with starting fluid and it will idle fine, but as soon as you give some gas it dies. We have replaced the plugs, cleaned the mass airflow sensor, checked fuse #1 that was recommended to reset something with the engine, but nothing has changed - any ideas would be appreciated - Thanks[/QUOTE
Old May 14, 2020 | 08:39 AM
lev's Avatar
lev
Starting fluid doesn't last long so dying after a bit is normal... sounds like you have fuel problem. I'd start with the relay, fuel pump, go from there.
FulangChang
Jun 21, 2019 08:19 PM
mattem
Nov 20, 2014 11:35 AM
MNWILD
Mar 27, 2011 03:57 AM
tjanae80
Oct 20, 2010 10:55 AM
89TempoGLS
May 29, 2007 05:54 PM
