1995 240 VIN engine code 83???
Old Dec 6, 2011 | 04:52 PM
red7218's Avatar
Default 1995 240 VIN engine code 83???
Anyone know the difference between a B230F and a B230F"D" in a 1995 240?? The VIN engine ID code is 83 which I found was a B230FD. Is there a difference in cylinder head gaskets? I don't see that engine in my gasket catalogs.
Old Dec 6, 2011 | 07:12 PM
lev's Avatar
lev
'93 was the last year for the 240 pretty much worldwide so if you got a '95, man, that'd really be something... As far as the gaskets, they are the same...
Old Dec 6, 2011 | 07:35 PM
Burn Stains's Avatar
Are you in Malaysia?
Old Dec 7, 2011 | 12:23 AM
red7218's Avatar
OK I'm an idiot, its a 940. Do you know the difference? The engine code is 83 B230FD What's the D about?
Old Dec 7, 2011 | 09:41 AM
bubba240's Avatar
RWD - 1994 B230FD engine vs 1993 B230F ?
Old Dec 7, 2011 | 02:27 PM
red7218's Avatar
Default pay dirt
Bubba: A 1995 940 B230F verses a 1995 940 B230FD
Thanks guys, but I finally found what I was looking for..
Just for anyone that might run across this thread at a later date and is wondering the same thing. This is second hand so treat it accordingly. I 'mnot telling where I found it..
Apparently, the B230FD has a different (M) camshaft, has a rounded tooth timing belt (and gears) that has a 100,000 mile service intervel, the cylinder head casting has a couple of extra egr?? passages, and the block has piston cooling nozzles.
Luckily, the first responder was right the gaskets appear to be the same.
leersobie
Jun 3, 2022 06:37 PM
Roger1689
Dec 27, 2013 01:45 PM
kvoos
Feb 1, 2013 07:08 PM
volvony2
Nov 15, 2011 05:41 PM
