240 Crankshaft Gear and Seal
Old Jul 3, 2016 | 07:34 PM
BlacJac's Avatar
Default 240 Crankshaft Gear and Seal
I need some assistance removing the Crankshaft Gear on my 1990 240. There is absolutely no room behind the gear for a puller or even a screwdriver. Any tips on getting this thing removed would be greatly appreciated. Also, what is the disk that is sitting directly behind the gear? It looks like a dust cover but it rotates freely, but it doesn't slide back and forth along in the direction of the shaft. Is this part of the seal?
Also, should I replace the seal while I'm in there? It's not leaking, though you can see some residual oil around the gear.
Any advice would be greatly appreciated.
Old Jul 4, 2016 | 08:21 AM
BlacJac's Avatar
OK. I figured this out, so if anyone else is facing the same issue here is what I did. I found a good video showing how the process should work:
. My gear however was frozen in place. So I hit it with penetrating oil several times and ended up tapping the gear very gently with a small hammer to free it. Once it broke loose it slid off very easily.
Old Jul 7, 2016 | 03:32 PM
Nichals's Avatar
as for that place, its simply a guide for the timing belt
some people remove them because they are as problematic as they are useful
Old Jul 7, 2016 | 06:04 PM
BlacJac's Avatar
OK, that makes sense. Thanks for the response Nichals.
mexicanfooddude
Apr 15, 2015 06:46 AM
rjpeek
Sep 17, 2012 05:34 PM
red7218
Sep 22, 2010 11:28 AM
ebrobb
Feb 15, 2007 02:52 PM
Volgrrr
Jul 15, 2006 12:03 AM
