crank pulley
Old 10-02-2005, 03:48 PM
whyflygti's Avatar
Default crank pulley
What is the magic Swedish trick for removing the 240 crank pulley? I have a puller but there is nowhere and no room to screw in the bolts. Am I missing something really obvious here?
Old 10-03-2005, 12:20 AM
Default RE: crank pulley
Once the screw is out then you can use 2 screwdrivers or prybars between the pulley and the timing cover and slowly work it off.
Old 10-04-2005, 01:23 AM
whyflygti's Avatar
thanks, Tech! Why I coul not get it off yesterday is beyond me, but two prybars and some patience and off it came. After that, changing the belt was the easiest one I've chnaged yet. It sure beats changing one on a New beetle TDI!
ZaphodBblbrux
07-02-2012 09:54 PM
guest01
11-05-2011 10:11 PM
VolvoMonki
12-01-2007 08:40 AM
dbheatherly
11-27-2007 06:24 PM
Reilly_S70GLT
09-05-2006 08:57 PM
Quick Reply: crank pulley
