89 Volvo 240 crank position sensor help
Old Jun 29, 2021 | 05:46 AM
Stephenstaly's Avatar
Default 89 Volvo 240 crank position sensor help
I have a 89 Volvo 240 wagon. It has the distributor on the front of the block and there is a sensor in the center of the trans bellhousing up against the block. I would like to manual swap the car and I'm tired of not being able to do that because I can't find a flywheel or a trans that will work with that sensor. Is there any way to delete it and still be able to run the car? Maybe a distributor I can drop in that already has it built in or something? Somebody has had to figure this out by now
Old Jun 29, 2021 | 07:43 AM
act1292's Avatar
Your car has the LH 2.4 fuel injection system coupled with EZK 116 ignition system. You would have to swap out these systems for older LH 2.2 fuel injection along with the earlier EZK ignition system (I don't know the version). This is necessary since the crank position sensor is an input to both the fuel injection and ignition systems. This would mean changing the ECU for the FI, changing the ignition module, changing engine wiring harness and who knows what other wiring is involved. Frankly, I prefer the LH2.4 vs. LH2.2 as I feel it is a more reliable system.
Old Jul 2, 2021 | 01:51 PM
I totally understand that and I don't mind the car at all I just really wanted to be a five-speed and the only transmissions and flywheels I can find are behind Red blocks and they don't even have the right flywheel and you cannot buy a brand new flywheel for this car it's completely discontinued which is total BS
And usually when I find a car in my location someone already took the transmission or anything I wanted I'm having a hard time even getting a transmission let alone a flywheel
joshpo83
Feb 11, 2024 10:54 PM
Stephenstaly
Mar 1, 2021 02:29 AM
ojo88
Jan 15, 2018 07:37 AM
jonqu
Sep 4, 2013 12:45 PM
starkeyd
May 5, 2007 01:07 PM
