92 Estate Wagon
Old Jan 30, 2019 | 09:32 AM
NDvolvo240's Avatar
Default 92 Estate Wagon
Hello, I am at a crossroad. I’ve had my wagon in the garage for three years. The motor leaks oil out of every orifice it seems, likely due to the fire trap being plugged. It just dawned on me, should I pull the motor and have it rebuilt? The body is in great shape and has potential. I know I’m not getting my money back out of it, but in order to properly fix it, it seems pulling the motor is the right thing to do. It has to get done this year or I need to get rid of it. Worth the expense? I have the resources to get it done, just maybe not the commitment.
Old Jan 30, 2019 | 12:39 PM
if all it needs is seals, there's no point in pulling the motor. fix the oil trap, replace the camshaft and crankshaft seals, and maybe the intermediate shaft seal, and you're probably good to go. only the rear crankshaft seal will require droppping the transmission, i'd fix all the others first and see if that one remains a problem.
Old Jan 30, 2019 | 01:48 PM
NDvolvo240's Avatar
Hey, thanks for the reply. I should have mentioned the rear main seal is most definitely blown. I bought the car from a friend who lived a block from my. They said it ran but leaked a lot of oil. I foolishly just filled it with oil and drove it home. It dumped a crazy amount of oil out in that short trip.
Old Jan 30, 2019 | 05:52 PM
jagtoes's Avatar
I got a leak in my rear main on my 89 740. It happened at about 100K when the flame trap plugged. Same with the front crank which I repaired. I left the rear as I just don't feel like pulling the transmission. Used a few bottles of some seal leak stop but it is at a drip level now. So I have 375K on it now and it still drips a bit but not a problem.
Old Jan 30, 2019 | 08:48 PM
lev's Avatar
lev
Fix the PCV first, the leaks may go away completely, will definitely get smaller. Then fix what's still leaking.
Old Jan 31, 2019 | 06:06 AM
act1292's Avatar
Are you sure that the large oil leak is coming from the rear main seal? A common problem when the flame trap gets clogged is the rear cam plug blows out. This plug is up on the head and leaves a large hole when it blows. All this oil will drip down the rear of the engine.
Old Jan 31, 2019 | 07:49 AM
jagtoes's Avatar
Yep good catch here . I had to replace mine too so it is one of the areas that blows out with a clogged flame trap.
92Sedan
Feb 28, 2016 04:18 PM
southpaw47
Apr 21, 2014 08:07 PM
Alexandria Shippee
Dec 21, 2013 10:05 AM
mmajarian
Feb 3, 2010 07:09 PM
floryed
Jun 4, 2005 04:53 PM
