93 940 Turbo Wagon - WONT START W/ NEW INJECTORS
Old May 1, 2021 | 03:34 PM
parziv4l's Avatar
Question 93 940 Turbo Wagon - WONT START W/ NEW INJECTORS
Just installed 4 new injectors ( https://www.rockauto.com/en/moreinfo...289044&jsn=393 ) hoping to fix a bad fuel injector / acceleration issue.
It cranks but wont start, I turned the key a few times before trying to crank to get fuel back into the fuel rail. Tried to start it 3 times without luck. It was starting fine earlier today.
Im pretty sure I have all the injectors seated fine and nothing seemed out of place putting the bolts back in.
Is there something I mightve missed replacing the injectors? Thanks.
Old May 1, 2021 | 05:45 PM
parziv4l's Avatar
Note: no gas smell for flooded engine, dont think im getting injector pulse at all. Tach does not move when cranking. I feel like I accidentally unplug something taking out the injectors on the first go. Check connections / CPS?
Old May 1, 2021 | 06:53 PM
Put the old ones back in and see if it runs
(it ran, you replaced something, now it does not run)
Old May 1, 2021 | 07:06 PM
parziv4l's Avatar
Yea I was planning on doing this just no time. I will do this tomorrow. If the old injectors work, whats the issue with the 4 new ones? No way all four or 2 or 3 of them are faulty.
Edit: The ones I ordered are EV1 injectors. Current ones have the nozzle that sticks out, different. I'll have to send these back and re order.
Old May 1, 2021 | 11:34 PM
lev's Avatar
lev
Injectors rarely go bad on these cars, why made you mess with them in the first place?
Old May 2, 2021 | 05:31 PM
parziv4l's Avatar
I put back the old injectors and car starts fine. Taking a second look no debris or damage to em. Going off topic, its had a performance issue past couple months. Lost some acceleration power, but can still get to 50/60 after some time. Just seems kind of sluggish. Noticeably harder to get to higher speed cold / cold weather. I think the gasket to water pump went bad so leaking a bit of coolant, but I think its also got a small oil leak near or just under timing belt. Or vacuum leak somewhere. Not really sure where to start on it.
Old May 2, 2021 | 05:49 PM
Injectors very rarely go bad - so a good first step would be to check for codes - on the early OBD system - are any stored?
And/Or start with basics - compression, good spark plugs, correct/good spark plug wires, what does it look like in the distributor cap, engine speed sensor - how does it test, is all the insulation still on the wiring, Throttle plate/throttle switch, basic idle - all clean and set properly?
Any air leaks @ manifold gasket for example? Air filter (should be fine unless covered in mud) , - but I've seen the foam noise insulation from the top of the air filter box block air flow into the AMM. Intake hoses - anything from the air mass meter to the throttle plate can (and does ) leak - how about the short hose leaving the intercooler - they burn through on the bottom -
You could have an Air mass meter problem - but everything else should be checked first - especially if there's no code related to it. Air Mass Meters are the most misdiagnosed part - and the OEM parts were expensive - so avoid the bad diagnosis of that one.
Old May 2, 2021 | 07:49 PM
parziv4l's Avatar
Alright, Ill put this down and get to it. I cleaned the MAF with MAF cleaner but no change. I havent checked all codes but 2 and 6 showed 111s. Do have a B2 122 no speed signal, think speed sensor went out months ago, speedometer doesnt work. Thanks.
Old May 2, 2021 | 11:39 PM
lev's Avatar
lev
MAFS cleaning hardly ever works. You may or may not have a bad MAFS and yes, it's a tricky part with all kinds of symptoms causing drivability issues. Sadly, the only sure way to know is by swapping it with a "good known" sensor, a "new" one often doesn't work these days confusing things further, and no, there is no new $40 or so good MAFS!
Ken Johnson
Jul 11, 2019 04:00 PM
Hobo
Mar 9, 2017 05:28 PM
Mfunes21
Dec 9, 2015 06:29 PM
burberry
Apr 23, 2013 01:42 PM
tdrendel
Feb 25, 2012 09:31 AM
