940 won't start after suitting for a year
Old Jul 21, 2013 | 03:38 PM
maryaus's Avatar
Default 940 won't start after suitting for a year
Wasn't started for a year. Was running perfectly till then. Front fuel pump replaced and working; cranks fine but wont start now. May need injectors, plugs ,wires, timing belt replaced. Help!
Old Jul 21, 2013 | 04:16 PM
Old Jul 21, 2013 | 11:34 PM
lev's Avatar
lev
You have to check all these things you mention. Not too hard to do: timing belt should be OK, is it moving the cam when you crank it?
You may need some fresh gas. Get the plugs out, clean them, regap them.
Squirt some starting fluid into the intake to see if it fires up. If it does, and dies, you know you have a gas problem...
Old Jul 22, 2013 | 12:03 PM
maryaus's Avatar
Default this is my line of thinking for this vehicle
fresh battery (one step up cc from oem)
fresh fuel (regular unleaded) 1/4 tank
sea foam 1/4 tank will rid of moisture and clean injectors
oil change if it has not had one in the last two thousand miles or one year
ngk iridium pre-gapped plugs
lifetime wires
complete tune up
check relays
turbo?
Old Jul 22, 2013 | 12:51 PM
use the correct stock copper bosch or ngk plugs, not iridium.
use bougicord sparkplug and coil wire set, not some 'lifetime' pretty junk sold at a local parts chain
if the battery holds a charge (as tested with a volt meter), no need to replace it.
does the car turn over when you crank it? if yes, pull a spark plug and inspect it, is it wet, smell like gas? plug sparkplug back into wire, use insulated pliers to hold the metal side of the plug against a ground, have friend crank engine over, do you see a solid spark ?
what year/version 940, which engine management system? does it have EGR? Pulsair?
Old Jul 23, 2013 | 05:40 PM
swiftjustice44's Avatar
If all else fails, check the codes.
mutambudzi
Aug 10, 2017 10:08 AM
Linkesh Diwan
Jun 17, 2015 03:29 PM
dcjcdc
Apr 21, 2013 05:42 AM
k
Oct 8, 2009 07:37 PM
