B6304S in 740 GLE wagon
Old Jan 14, 2014 | 02:18 PM
The wallrus's Avatar
Default B6304S in 740 GLE wagon
I'm not quite sure where this belongs so It's going here . I may have the opportunity to get a free 24v inline 6 out of a 900 series. I would like to put it into my 745 which has the 2.4 8v in it. Problem Is I don't know enough myself to get it done. my question is what would I need to make it work? could I keep the trany that's in the 740 there? would I need to replace the entire harness or would I just need to swap computers? Would I need a new drive shaft made ect? any information helps. Also I would have access to the full car not just the engine so any electrics or what not I can get out of it.
Why I want to do this. The N/a 8v is just plane slow and sucks gas. the 24v has twice the power about and not any worse on gas.
thanks.
Old Jan 14, 2014 | 02:26 PM
you'll need to swap EVERYTHING from that 960, all wiring harnesses under the hood, the ICU and ECU are completely different, the dashboard wiring is COMPLETELY different on a 960, so nothing will mate (the ECUs and fuse and relay panels are all under teh dash, but on a 960 they are so different you won't even recognize them). you'll need the 960's electronic controlled transmission.
a turbo upgrade would be a LOT simpler.
oh, btw, that whiteblock 960 I6 is a very expensive engine to maintain, it requires a lot more TLC and if it ever breaks its rather fragile timing belt, you're looking at an impossibly expensive valve job.
Old Jan 14, 2014 | 02:33 PM
TIPSP's Avatar
Got Boost?
Here is some inspiration.
Chris' awesome 960r
Chris Wiita's 1995 960R - Turbobricks Forums
Old Jan 14, 2014 | 02:37 PM
Chris' awesome 960r
except thats a 960 motor turbocharged in a 960 car.
Old Jan 14, 2014 | 02:48 PM
So what I'm getting is It would be a lot of work and time. But I wouldn't be spending more than $200 since I have the whole donor car to work with. the biggest problem for me would be time. I don't want to be without it for more than two weeks.
Old Jan 14, 2014 | 02:52 PM
I doubt this could be done in under 6 months.
Old Jan 14, 2014 | 02:55 PM
lev's Avatar
lev
You know a 940 is worth more and is more desirable than a 960, for a reason.
What you want to do is difficult and the end result will be a lesser car. And no, you won't get it done in two weeks unless you are some kind of a 'gear head' wizard.
Old Jan 14, 2014 | 03:19 PM
dnarby's Avatar
If I was going to do this (having never done one myself) I would budget a lot more than two weeks, and I would buy a beater and drive that while I did the swap over the Summer.
I would also instead look into parting out that free donor motor here or on Ebay, getting a 5.0L Ford Mustang motor/tranny and putting that in instead. Moar powa! ...And better mileage on the highway than either.
Old Jan 14, 2014 | 03:46 PM
Ok, well thanks for the help. Sadly I can't sell the parts of the donor as it is one of my teachers and the deal was he would get my engine. I think Ill just save up for a turbo conversion and worldclass t5 trany
Old Jan 14, 2014 | 09:48 PM
TIPSP's Avatar
Got Boost?
Yeah. It was motor and transmission inspiration.
Turbo b230 motor is fairly cheap and fun.
Old Jan 14, 2014 | 10:19 PM
the most cost effective turbo conversion is to find a solid 740/940 turbo and buy the whole car. the 94/95 940 turbos have additional cylinder head and piston skirt lubrication which improves longevity.
steelheaddan
Feb 5, 2011 06:54 PM
cosmiclobster
Aug 2, 2006 10:22 PM
TedH
Mar 20, 2006 08:32 PM
wufmama
Feb 20, 2006 11:44 PM
jonesje
Jan 9, 2006 08:36 PM
