Bulb Integrity Sensor / Bulb Failure Relay, IS IT WITH THE REST OF THE RELAY'S ?
Old Oct 23, 2008 | 09:51 PM
dads 740 turbo's Avatar
Default Bulb Integrity Sensor / Bulb Failure Relay, IS IT WITH THE REST OF THE RELAY'S ?
http://www.fcpgroton.com/product-exe...ategory_id/172
IS THIS WITH THE FUSES AND RELAYS UNDER THE RADIO?
I SUSPECT IT TO BE MY PROBLEM
My tail lights also have a host of problems. THe indicators don't function nor do the back up lights and when I have either indicator engaged the brake lights on both sides flash. When I depress the brake pedal in drive the left indicator stops all together.
I have replaced the fuses cleaned all the contacts on the flasher and bulb relays-,
ISSUE WITH BACK-UP LIGHTS, TURN SIGNALS, AND BRAKE LIGHTS..........WHEN I BRAKE WITH TURN SIGNAL ON........WORKS FINE UNTIL I BRAKE............BACK-UP LIGHTS WORK FINE UNTIL I BRAKE
ICANT FIGURE IT OUT YET............... BUT MAYBE THIS IS MY FIX.....????????????????...
Old Oct 24, 2008 | 06:43 AM
Default RE: Bulb Integrity Sensor / Bulb Failure Relay, IS IT WITH THE REST OF THE RELAY'S ?
Yes it is located there. Back left hand corner.
Old Oct 24, 2008 | 09:38 AM
k's Avatar
k
Does your Cruise control work? If it doesn't then you can be sure its the Bulb Failure Relay that's causing the problem
I had the same problem on our car, Back brake lights weren't working, then a day later we noticed that the Cruise control wasn't working...read on here (this forum is great) that the Bulb failure relay was it- got a used one for $50 and bingo was your namo...fixed...although make sure the contacts are good and clean...first time I plugged it in it didn't fix the problem, then I cleaned the bulb sockets etc well and problem solved.
Good Luck!
K
Old Oct 24, 2008 | 06:54 PM
dgm76513's Avatar
I have a spare actually. PM me with your address and we'll make an arrangement.
I grabbed one from the pick and pull just in case. That and a fuel control relay.
Mine messed up as well earlier, but I tested it and re-soldered some cracked connections and that fixed my problem.
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
keg22
Mar 20, 2010 10:14 AM
briang232000
Feb 12, 2010 10:34 PM
wyomingresident
Nov 16, 2008 09:52 PM
