cant get my speedometer working any ideas
Old Feb 14, 2018 | 05:19 PM
maxxmcdaniel's Avatar
Thumbs down cant get my speedometer working any ideas
okay ive checked the sensor running to my rear dif its plugged in the wires are fine because i saw a video that said if your abs light is on and the speedometer isint working its probably that but its fine so does anyone know how i can fix it yes my abs light is on and no speedometer everything else on my cluster works fine. thanks again proud 940 owner
btw its a 1991 940 turbo with the b230ft.
Old Feb 14, 2018 | 09:31 PM
Moetheshmoe's Avatar
'91's are notorious for bad capacitors in the speedo. You can try and solder in new ones or upgrade to a later and better year:
https://www.volvoclub.org.uk/faq/Ele...struments.html
https://www.volvoclub.org.uk/faq/Ele...eterRepair.htm
Old Feb 15, 2018 | 04:17 AM
IIRC, a later dashboard with the fixed speedo circuit will have the wrong gas gauge reading. or something annoying like that.
Old Feb 15, 2018 | 11:10 AM
That's true, but if he has access to a local pick n pull, the parts(including a different gas gauge) are readily available and cheap. Better than sending to be repaired which can cost over $300.
Kyin01
Jul 26, 2010 12:08 AM
pianoman52
Jun 19, 2009 10:12 AM
04arghh
Aug 23, 2007 02:44 PM
dcisne
Feb 12, 2007 09:24 PM
defuse
Jul 18, 2005 10:34 PM
