Coolant Temp Sensor
Old Jan 18, 2019 | 06:19 PM
tylswil's Avatar
Default Coolant Temp Sensor
Where the heck is this thing located. I’m sick to death of paying a mechanic to fix little things like this. Please help.
Old Jan 18, 2019 | 06:27 PM
lev's Avatar
lev
It's under the third intake runner, screwed in the head with a plug on it naturally... It's hard to get to it with the intake manifold on but not impossible. Unplugging it the hardest, then usually with a long extension there is a straight shot onto it, forget the size, (19mm?)... Coolant loss is minor.
Old Jan 18, 2019 | 06:29 PM
tylswil's Avatar
Do you think it’s possivle this could cause my cold start issues? With it loping for about 20 seconds. The engine runs fine otherwise.
Old Jan 18, 2019 | 07:37 PM
you test it by measuring the resistance when its hot, and when its cold. problems are as likely to be the connector or the wiring harness as the actual sensor.
Old Jan 19, 2019 | 10:48 AM
lev's Avatar
lev
It absolutely can be caused by this sensor! This is the first thing I'd look at in case of hard cold starting, well, after battery...
Old Jan 19, 2019 | 11:16 AM
tylswil's Avatar
Sweet thank you very much
Old Jan 19, 2019 | 03:01 PM
silvermine's Avatar
this guy changed out the CTS without removing the intake manifold. caution for language but like his style
Old Jan 19, 2019 | 03:09 PM
tylswil's Avatar
Will this be in the same location as a 940?
Old Jan 19, 2019 | 04:03 PM
jagtoes's Avatar
I just replaced mine in my 89 740 but I was also changing the PCV box and cleaning the throttle body. If you have the TB off it's pretty easy. I used a long 3/8" extension and a 7/8" deep socket. Was a pretty easy job and when I did it on a cold engine I didn't get much water come out. If you keep the cap on and no pressure on the system coolant just dribbles out.
Old Jan 19, 2019 | 04:16 PM
silvermine's Avatar
should be, yes.
Newtovolvo88
Dec 9, 2018 09:11 PM
Sufarry
Jul 27, 2018 09:42 PM
xerxes66
Mar 13, 2017 02:54 PM
du907
Jan 15, 2014 06:32 AM
Shartzy4
Apr 8, 2007 07:33 PM
