Cruise control and other vacuum related issues...
Old Nov 14, 2011 | 11:16 PM
failedstar's Avatar
Default Cruise control and other vacuum related issues...
hey hey, new to the bricks game, haynes on order, but hoping to find a vacuum diagram for my 81 244 gle (oz edition). cruise stopped working and fuel economy shot to ribbons, sure its just a loose hose bumped free on country roads, but cant spot it... muchos gracias
Old Nov 14, 2011 | 11:48 PM
Never hurts to ask but you are in the 850 section.
You would have better luck here:
Volvo 240, 740 & 940 - Volvo Forums - Volvo Enthusiasts Forum
Do you have a 850 too?
Old Aug 31, 2021 | 01:11 AM
sphinctersaysmove's Avatar
Question
Having the same issue /w '91 Volvo 24O(sedan) non/turbo ... Cruise Control stopped working ; can hear sometype of noise when attempting to engage cruise control, as thO it is making the attempt @ setting desired speed, once release button NOTHING. Also hearing a hissing sound from under dash when brakes are applied , gas milage as gone dramatically lower along /w it! Have checked both 'check valves'
- 1.) front of brake booster
- 2.) top of motor running horizontal when looking @ motor /w hood opened
Both checked out fine [[b]BLOW TEST = open one direction-closed the other.]
So, if someone has any advice as to what could be the issue, and/or how to fix these problems i'm having , it would be GREATLY APPRECIATED! i contemplated possible issue /w charging/alternator being as høw car will bog-down and seem to almost die when coming to a stop, but i honestly don't knOw! replaced alternator just last year when chasing down a strange electrical/charging problem that ended up being the Harmonic Balancer needed replacing.
** Wana talk about a frustrating ordeal? at times leaving me at a complete lose! ended up replacing ECU , spark plugs / wires, 2 alternators, new ignition coil, and stripping/chasing numerous wires in search of shorts before stumbling upon some info regarding the 2 piece Harmonic Balancer and the rubber between the two pieces failing causing things to not turn as they should. But, that's all in the past, and GRATEFUL for iT! **
so, ANY help on this seeming vacuum problem(s) i'm having now would be much appreciated, THANK YOU!
Diarmuid89
Oct 24, 2013 06:46 PM
rosicler
Aug 8, 2011 11:35 PM
radio16
Feb 14, 2010 09:40 PM
VolvoViking
Mar 23, 2009 06:55 PM
jmkdparks
Feb 24, 2008 06:02 PM
