Exhaust Manifold Perhaps?
Old Jun 24, 2012 | 08:55 PM
piv15's Avatar
Default Exhaust Manifold Perhaps?
There's a loose manifold next to the engine. Not really sure what the manifold is to, so I figured I'd post pictures and see if anyone else knows what it's to, and it's importance. Should it be connected to something? If so, how should I go about doing so so it'll stay on where it's supposed to go.
Close up of manifold:
https://i.imgur.com/AFSjT.jpg
General Area Its In:
https://i.imgur.com/HsZgz.jpg
Old Jun 24, 2012 | 09:02 PM
thats the dreaded heat riser hose. there's a mechanical thermostat in the bottom of the air filter box, and if its very cold out, its supposed to suck air from that pipe thats been pre-warmed by the exhaust manifold. everyone I know has wired that thermostat permanently closed, and leaves the hose in your first picture connected only because its a smog check item. those thermostats have a tendancy to jam open, then the hot air cooks the MAF.
Old Jun 24, 2012 | 09:33 PM
piv15's Avatar
Hmm... Probably don't want something to burn up... what do you recommend I do with the manifold? And is there anything I should do with said thermostat, or just leave it alone?
Old Jun 24, 2012 | 11:03 PM
piv15's Avatar
So is it a major problem?
Old Jun 24, 2012 | 11:20 PM
no, having that disconnected isn't a problem at all, unless you live where they smog inspect, they might fail you for that. just put that foil duct back over the manifold thing it was on originally, use a hoseclamp to keep it in place.
Old Jun 24, 2012 | 11:40 PM
piv15's Avatar
Alright! Thank you
jorhyne
Jun 19, 2015 04:08 PM
Jrobi59
2001-2013 model year XC70
May 6, 2014 12:27 PM
BlazeS70
Jul 11, 2009 09:29 PM
nickb
Nov 13, 2007 03:40 PM
bagelluvr
Jul 20, 2007 09:21 PM
