front control arm bushings
Old Jan 20, 2016 | 07:15 PM
silvermine's Avatar
Default front control arm bushings
is there anything one can use to quiet same? it's 15 deg F here and they are making some creaking noises. wd-40 maybe? or something else?
Old Jan 20, 2016 | 09:05 PM
lev's Avatar
lev
Brake fluid works and doesn't damage rubber. WD40 will damage rubber.
Old Jan 21, 2016 | 06:08 AM
act1292's Avatar
If they are creaking then they need replacing. The cause of creaking is the rubber has separated from the metal sleeve. I have the same problem on my mercedes and I am waiting for warmer weather to fix
Old Jan 21, 2016 | 10:15 AM
lev's Avatar
lev
True that! Brake fluid or any lube is just a temporary fix, and may be not be that much help at that...
Old Jan 22, 2016 | 08:48 AM
silvermine's Avatar
K will try that. thanks
too cold to work out there for long... ughh.
Old Jan 22, 2016 | 03:36 PM
note that brake fluid can strip paint so be careful using it.
MEWEAVER
Aug 5, 2013 12:14 PM
Platinum52
Jul 17, 2009 07:33 PM
sy381
Jul 2, 2008 07:33 AM
dharmamama
Mar 19, 2008 08:44 PM
nandrolone
Dec 28, 2006 11:14 AM
