gremlins, no door locks, courtesy light no auto, and ac fan runs when key is off
Old Nov 17, 2017 | 09:46 PM
Jjona5's Avatar
Default gremlins, no door locks, courtesy light no auto, and ac fan runs when key is off
So I just picked up this car and I've never owned a volvo. Before I go chasing all the wires I just want to see if there is something in particular I should look for. When I got the car the fuse for the overhead and power locks was blown. Hoping it would fix my door lock issue I replaced it and it hasnt blown since but no door locks. Now if I flip the switch I get light overhead but no auto. I also don't have any dash lights except for the gauge cluster. None of the other lights work(shifter, ac, and etc). If I leave the fan on and turn the car off the fan remains running. Have you guys ever unhooked your lift pump to see if it is pumping properly? The car runs and drives okay but I just get this feeling the lift pump isn't doing its job.
Is the only way to operate the locks the drivers door lock? Should it lock or unlock when put into gear or cranking?
Old Nov 17, 2017 | 11:36 PM
lev's Avatar
lev
Year, model?
Old Nov 17, 2017 | 11:48 PM
Jjona5's Avatar
Oh apologies! 1990 240DL automatic. Also I just found a thread that showed how to jump the fuses to test just the tank pump.
Old Nov 21, 2017 | 12:32 PM
the locks should lock/unlock with the either front door key, or when you work the drivers door lock. they should NOT automatically lock under any other condition.
a dead in-tank pump will manifest itself by 1) making the regular pump noisier and 2) causing fuel starvation issues at heavy throttle as the gas tank gets below about 1/3rd full
brian0708
Jul 1, 2021 05:08 PM
gstolting
Aug 9, 2017 11:32 AM
wumarshall82
1998-2000 model year V70
Apr 1, 2017 06:15 PM
shirley
Sep 24, 2015 12:23 PM
MER
Apr 20, 2009 10:47 PM
