Hard to start
Old Jul 20, 2022 | 08:23 PM
Sckeet05's Avatar
Default Hard to start
Hi everyone. I’m new to the forum and I’ve searched for so long but I can’t seem to figure out my problem. I recently got a 1989 Volvo 240dl. it doesn’t like to start up. Sometimes it takes me cranking the engine for a solid minute. Then i hear it fire, then fire again, and again till it finally starts into a rough idle. It is pretty much straight pipes and shoots flames, which leads me to believe it’s running rich. I have a new maf, cps, fpr, cap and rotor, and spark plugs. And when I unplug the o2 sensor I don’t notice any difference in the engine. But the check engine light doesn’t come on either Please yall I’m lost
Old Jul 20, 2022 | 10:57 PM
Compression? Fuel pressure? Cam timing? Leaking injector? Codes? Do you know how to check codes? https://www.volvoclub.org.uk/faq/EngineOBDCodes.html
O2 sensor only does something after the engine has been running for a minute and a half. Sensor has to heat up to 700 degrees or so to give a valid signal and even then it can't change the mixture very much. If you think it's a problem measure the output (with a voltmeter) or leave it unplugged.
Old Jul 21, 2022 | 08:07 AM
Sckeet05's Avatar
Well I know I have compression but there are no codes. I also have new tank pump and filter. But havnt checked fuel pressure. This morning I went to start it up and it started up just fine(with a choppy idle) I’ll probably be getting a fuel pressure gauge soon. What if there isn’t the sock on the in tank pump? Could that be getting clogged?
redgecko1
Oct 28, 2015 08:24 AM
ashort
Mar 16, 2015 01:26 AM
JJR
May 26, 2009 05:07 PM
Woodlockashell
Dec 31, 2008 09:49 AM
thatsmrgimp2u
Jul 3, 2005 06:50 PM
