Help with blown coolant hose
Old Jun 17, 2023 | 09:07 AM
McafeeShred's Avatar
Default Help with blown coolant hose
Hi guys, just got a Volvo 940 GLE non turbo the other day. It has a leaky heater core, which I'm intending to fix, but the issue that's just happened is that I was driving with the heater on full, which was not getting warm. Then my top coolant hose blew open from the engine to the radiator. Is this just a simple fix or a sign of something more? Maybe a head gasket?
Old Jun 17, 2023 | 07:46 PM
Psaboic's Avatar
I would suspect a loose hose clamp first and foremost. With the engine cool, I would tighten all hoses/clamps and then drive carefully and see what happens. While a head gasket can cause a hose to blow off due to pressure, a better way to check is see if you have a lot of white smoke out the tailpipe (more than just the usual white vapor from a cold engine start). Also with the engine cold, take off the cap to the coolant reservoir and then start the engine. If you see a lot of bubbling in the coolant in the reservoir then yeah, the head gasket is bad. Good luck.
Old Jun 26, 2023 | 11:06 AM
lev's Avatar
lev
With the leaky heater core you cannot correctly diagnose the cooling system or the head gasket. You have to bypass it first, or replace it. Bypassing it first is the way I'd go.
marcofd89
Nov 4, 2016 10:14 AM
s80turbo
Apr 24, 2011 06:31 PM
litehwk356
Feb 24, 2009 01:16 PM
airmiller44
Dec 3, 2008 08:05 AM
astronut
Oct 14, 2008 08:28 PM
