just bought a 93 940...with issues.
Old Aug 23, 2008 | 10:53 PM
volvorover's Avatar
Default just bought a 93 940...with issues.
Hello all,
Just bought a 93 940 with 200k on it.
Im new to the volvo scene and i just had a few questions. The steering wheel shudderes when i brake, i was notified that the rear rotors are warped...even though they were replaced a year ago....something i should fix soon?
There is a loud click metal noise when i change gears ...it sounds like something is loose? any ideas? its quite noticable....and is worrying me...its loud.
The brakes make a sqeeling noise....not a big issue ..i think its just the quality of the pads but its annoying.
What should i use for oil...the owner said he put synthetic in it...and the size of wrench for the plug? I just changed the spark plugs and that went ok..its running great. Any maintenence things i should jump on....i just dont want to be caught out, the timing belt was changed..along with the spark plugs.
thanks all im very grateful for any help i can get.
Old Aug 26, 2008 | 04:15 PM
wojeepster's Avatar
Default RE: just bought a 93 940...with issues.
check your universal joints they may have play and be making the loud cllick. yes replace warped rotors, that may fix your steering wheel issues too. I changed to volvo brand brake pads to rid myself of annoying but harmless squealing (fcpgroton)
Old Aug 26, 2008 | 07:24 PM
blue goose's Avatar
Is it an automatic or a stick? I'll assume stick. The metal clicking noise when changing gears could be shift linkage. The bushings wear out. I would be surprised if your bushings are in good shape if they're original.
Old Aug 27, 2008 | 09:06 AM
stevee's Avatar
Check the front calipers for corrosion on the slide pinswhere the calipers move in and out when braking.
If these get frozen in place, it will cause the caliper to apply brake pressure to one side of the rotor only, resulting in warped rotors and bad vibration when braking.
You can buy the slide pins as a replacement item.
Just a hint
steve
Old Aug 27, 2008 | 10:13 AM
volvorover's Avatar
nice thanks guys. its a automatic.......so it wouldnt be the linkage. so im guessing the noise is the cv joints. well at any rate it looks like im doing a brake job. okay so. replace rotors and pads pretty much.
Old Aug 27, 2008 | 05:31 PM
blue goose's Avatar
OK, automatic. I agree the loud click when changing gears is likely U-joints or center support on the driveshaft.
Brake job time. I don't fool around anymore with various pads. Just plain ol' Volvo rotors and pads. Tasca Volvo has good prices. tascavolvoparts.com Also FCP and IPD have good rotors and pads.
Sailing_Faith
Jan 17, 2009 11:47 AM
valfrid
Oct 27, 2008 10:16 AM
jarablue
Mar 28, 2008 09:54 AM
BigSection
Aug 10, 2006 12:26 AM
postdoc99
Apr 27, 2006 10:33 PM
