Motor swap Q's
Old Jun 21, 2012 | 06:55 PM
kburgess's Avatar
Default Motor swap Q's
Got a 1988 745t, and a 1990 744t parts car. I want to eventually swap out the K motor. What issues would I run into swapping the 90' into the 88'? I am at the understanding that they have different fuel injection systems, but would I really have an issue? The 90' motor is undergoing a small rebuild with some mods. Cam, brown tops, 15g turbo, and 3inch exhaust after install. Am I in for trouble, or will I not be regretting this?
Old Jun 22, 2012 | 12:47 PM
swiftjustice44's Avatar
Simplest thing in the world. Yes, the 90 car uses LH2.4 rather than the LH2.2 of the earlier car. There are 2 ways to go, convert the motor to 2.2 or swap in the engine harness from the turbo car and use the turbo ecu/icu. If you convert the car to LH2.4 you will need to use the flywheel/flexplate. If you swap the motor to LH2.2, you will need to swap distributors. Personally, I prefer LH2.4, so I'd swap in the engine harness (complete w/ resistor pack and mini-harness) and swap flywheel/flexplate.
Old Jun 24, 2012 | 08:58 PM
kburgess's Avatar
Thanks, I knew there was a few things to look for, now I know.
comrade904
Jan 26, 2010 09:19 AM
Rsterns
Jul 30, 2008 11:10 PM
S70needsboost
May 2, 2008 03:08 PM
ProMischiefMaker
Jul 14, 2007 09:47 AM
ProMischiefMaker
Jul 12, 2007 04:04 PM
