Oil sensor light - no show
Old Sep 25, 2014 | 01:10 PM
Dagaan's Avatar
Default Oil sensor light - no show
I'm almost ready for the test that will absolve my '86 DL 240 from the catacombs of having had a salvage title. It's an electrical test and all lights need be working. My one missing one is the oil sensor light - the wire may have got shorted. How could I run a wire from the sensor to the dash? Any clues? Thks.
Old Sep 25, 2014 | 01:42 PM
the oil pressure sensor is on the RIGHT (exhaust) side of the engine, on the side of the block, under the exhaust headers, and right next to the oil filter. IIRC (its been awhile), this wire goes into the same harness bundle as the D+ wire from the alternator, which is right next to said oil filter and oil pressure sensor.
first thing I'd check is if the wire is even there and connected. if it is there, disconnect the wire and temporarily short it to ground with the ignition switched on, the light should come on. if it does, then the sensor itself is probably bad. if it doesn't come on, then the bulb may be out, or the wire may be bad.
on a 87/88 (I don't have 86 prints), its a black wire that goes to pin 31/5 on the back of the instrument panel, connector 31 is the full circle one.
Old Sep 25, 2014 | 03:53 PM
lev's Avatar
lev
By ALL the lights they mean driving lights, head lights, brake lights, etc. Nobody cares about the oil light. Fix it, but you don 't need it for inspection!
Old Sep 25, 2014 | 04:20 PM
I would suspect this varies by jurisdiction. I know california verifies the CEL, if provided, lights up at ignition on and goes out at start.
Old Sep 26, 2014 | 09:44 AM
lev's Avatar
lev
CEL is part of the emission system, a different deal.
Old Sep 26, 2014 | 08:24 PM
Dagaan's Avatar
Thanks Lev - yup - yr right the oil doesn't matter
Old Sep 26, 2014 | 08:25 PM
Dagaan's Avatar
Thanks!
Old Sep 26, 2014 | 08:27 PM
Dagaan's Avatar
Thanks Pierce - I've copied the info and will try and make it happen - tho it's true the oil doesn't matter in this test but of course you want to have that light. I find it amazing and impressive that on an 18 year old Volvo most of the electrics do still work.
nuclearseal
Aug 17, 2022 01:48 PM
iceberg8389
Jul 6, 2015 12:20 PM
Ebolavoodoo
Jun 26, 2006 01:13 PM
Bender
May 15, 2006 06:54 PM
rpm
Jun 10, 2005 02:42 AM
