Please help my windows won't role up
Old Sep 7, 2014 | 09:24 PM
Ricerocket's Avatar
Default Please help my windows won't role up
Ok I'm new to this but my power windows on my 1990 volvo 740GL will not role up and I have checked the fuse and checked the connections to the switch box, and all seemed fine to me. Please help
Old Sep 7, 2014 | 09:35 PM
next step is to verify power is getting to the switches on the drivers door, with a volt meter or a test light. they pass through those switches before going to the other doors.
also check the power bypass relay, 2/6, which is located in position J of the main relay panel behind the ashtray (helps to remove the cigarette lighter+tray to access the relays as they are forward from the fuses).
Old Sep 7, 2014 | 10:11 PM
guest01's Avatar
What is a switch box?
Old Sep 8, 2014 | 01:23 PM
lev's Avatar
lev
Check for wire breaks at the door, where the wires pass through from the body to the door: even inside the rubber housing there may be a break...
grimlock
1998-2000 model year V70
Nov 2, 2013 06:54 PM
mjohnny
Mar 18, 2013 02:35 PM
TrouperL
Aug 20, 2012 02:18 PM
Trejor
May 27, 2011 08:06 PM
Modifier
Nov 17, 2008 08:29 AM
