Push button Start
Old Dec 20, 2007 | 02:08 PM
slim109's Avatar
Default Push button Start
Ok so here is the situation. I went away to college and my mom started driving my 1987 740 GLE. One day she broke the key off in the ignition and no one could get it out. Instead of re keying the car I just asked the mechanic to drill out the ignition so I could just turn the ignition switch and start the car thinking perhaps I could turn the car into a push button start on my return from college. Now I am back and have looked and looked and cant find a write up on how to do it especially considering the situation that I am in with the drilled out ingnition. I was wondering 1) If you have a write up somewhere on how to do this or any experience that would help me and 2) If no one has a write up, if someone knows what pins are doing what with each turn of the key. That way I could just rig up a switch to turn the correct pins on for the run position and then have a button hooked up to the starter.
Sorry if that last part was confusing any help anyone has will be helpful.
Old Dec 24, 2007 | 11:59 PM
Beardog's Avatar
Default RE: Push button Start
The first position is power for the accessories, the second is power to the engine, the third with the spring return is a switch to provide power to the starter motor. You want tosolder the push button to the last contacts for the starter. When the push button is pressed it will make the connection for power to the starter and when the spring returns the button, the switch is opened and no power.
Hope this makes sense and gives you what you want.
Old Nov 26, 2021 | 11:10 AM
iaguilera's Avatar
How about a diagram?
Old Nov 26, 2021 | 04:24 PM
lev's Avatar
lev
These are posts from 2007!
Better start a new tread if you have a similar issue.
Old Nov 26, 2021 | 08:29 PM
91Volvo240survivor's Avatar
spend a little and make it an auto start
Ken H
West
Mar 6, 2019 05:35 PM
nekvolvo
Oct 8, 2018 01:52 PM
Donkeyplonk
Jul 25, 2018 11:10 PM
Lonestar of David
Jun 29, 2013 10:29 PM
Dons Volvos
Oct 12, 2011 09:32 AM
