replacing shifter knob
Old Sep 27, 2011 | 05:55 PM
brickrunner's Avatar
Default replacing shifter ****
I bought a new shifter **** and would like to know if the over drive switch wires have a plug or do I need to cut the wires that go to it, thanks.
Old Sep 29, 2011 | 04:32 PM
and240res's Avatar
on my 240 i popped the square button on top with 2 flatheads one on each side, it pops up and then you can see the OD plug right behind the button
Old Sep 29, 2011 | 08:34 PM
I popped the switch and I don't see a plug on mine. The wires are soldered directly to the overdrive switch and I doubt that there is a plug in the console. I guess they saved money by omitting the plug. It is starting to look like my only option is to detach and resolder the switch once the new shifter **** is in place.
Old Oct 8, 2011 | 11:24 PM
Sambar Stag's Avatar
Default OD button
I assume that your car is a manual ; on my 245 M46 4 speed manual there is a connector under the carpeting on the passenger side up on the center tunnel. IIR, loosening the boot will enable you to peel up enough of the carpet to access it. Then the switch can be pulled out through the center of the shift lever, with about a foot or so of wiring attached.
Old Oct 9, 2011 | 01:35 PM
No it's an automatic so I guess things might be different.
readvl
Apr 15, 2015 10:01 AM
mark850t
Sep 29, 2011 11:08 PM
scouttyboy
Jul 8, 2008 05:35 PM
map1470
Jun 20, 2007 10:47 PM
bambam
Feb 15, 2006 04:42 PM
