Smoking on turbo side of engine...
Old Dec 30, 2022 | 04:27 PM
herbiedriver's Avatar
Default Smoking on turbo side of engine...
94 940 turbo, son says car was hesitating, not running well when into the boost. Pulled in, smoking from the turbo side of engine, can't quite see where from and it's now smoking from exhaust, smells like oil. Antifreeze is not oily or discolored, but a day later reservoir is almost empty. Oil is normal, no indication of water.
It's been too cold to explore further (-10), and I am looking for leads to explore later.
Headgasket?
Turbo oil seals?
Rings?
Things to look for when it gets warmer...
Thanks in advance
Old Jan 7, 2023 | 02:53 PM
Rvd9431's Avatar
Pull off turbo cold side intake and wiggle the compressor wheel see how much play she has.
Pull spark plugs and look at. A shiny clean on might indicate the presence of coolant, or a bad head gasket. Smell the exhaust see if it smells sweet.
Old Jun 12, 2023 | 05:54 PM
Update:
Rebuilt the engine, bored .060 over, new pistons, rings, bearings all around. Head surfaced, valves lapped and seated...
Rebuilt the turbo using an ebay kit for seals, etc.
Got it all put back together and fired up! Rough idle, hesitation when given a bit of throttle, suspect cap and rotor replacing those in two days (when NAPA gets them in stock)
Now I still have oil smoke on the turbo side, when accelerating or at a standstill and you give it gas, smoke from the manifold side and out the exhaust...
Turbo done??? Any insights would be appreciated!
Old Jun 26, 2023 | 09:34 AM
Last reply on this topic, nothing is worse than an unsolved/closed chat.
Ended up replacing the turbo cartridge, had leak from the water side to the oil side internally, causing all sorts of grief, now all is well in the world, $188 well spent.
KaylaBishop
Apr 29, 2018 10:02 PM
Alex867
Mar 14, 2008 12:51 PM
97gator
Feb 16, 2008 09:51 AM
rmmagow
Jun 21, 2006 08:46 PM
montalvo
May 9, 2005 10:37 PM
