Starter issue
Old Mar 15, 2019 | 06:36 PM
Ross Miner's Avatar
Default Starter issue
I have a 1986 740 GLE wagon and every once-in-awhile when i try and start it the starter clicks and doesn’t turn the motor. When this happens I turn the motor by hand then I turn the key the car starts. Usually when I turn the key the car starts right up. Is that a sign of a bad starter
Old Mar 15, 2019 | 07:59 PM
jagtoes's Avatar
Could be the solenoid or the starter. May be the brushes in the starter. Then again how good is your battery. I would make sure the battery is fully charged and check the connections at the starter. The clicking sound is the solenoid trying to push the pinion gear into the flywheel and make contact with the starter motor.
Old Mar 16, 2019 | 03:37 AM
Ross Miner's Avatar
I charged the battery about a month ago. The clicking started recently. Where is the starter located
Old Mar 16, 2019 | 07:12 AM
jagtoes's Avatar
Looking from the front of the car it will be down on the right side low and in the rear of the engine.
Old Mar 16, 2019 | 08:36 AM
silvermine's Avatar
you could also check/clean ground wire coming from negative terminal on battery.
Old Mar 16, 2019 | 03:24 PM
follow the fat red wire from the battery + terminal, it goes directly to the starter. the starter is along side the transmission
Old Mar 17, 2019 | 10:34 AM
lev's Avatar
lev
Most likely you have a bad starter that needs to be changed... $60+ an hr labor.
tomtoczek
Feb 11, 2019 11:38 AM
Henri Jeret
Jun 24, 2016 06:36 PM
bemerman
Jan 20, 2014 08:18 AM
dcwave
Mar 2, 2013 09:10 PM
bobgolf2174
Sep 3, 2009 01:41 PM
