Sunroof does not work
Old Jan 30, 2012 | 02:38 AM
blazerman1994's Avatar
Default Sunroof does not work
I have a 92 volvo 940gl with a power sunroof and it wont open, could the switch be burned out?
Old Jan 30, 2012 | 05:40 PM
swiftjustice44's Avatar
Yes. After checking your fuses to make certain it has not blown, the switch is the most likely culprit. The motors are stout and seldom fail. If you wish to rule out the motor, you could remove the motor cover and use a test light to see if it gets power when the switch is used. If you need a switch, drop me a PM as I keep several known good ones for my car...more than I probably (hopefully) will ever need.
Deepesh
Jul 17, 2009 07:49 PM
Deepesh
Jul 11, 2009 09:38 PM
tr_car_nut
Feb 13, 2008 07:58 PM
Lichty17
Oct 11, 2006 09:31 PM
mtidwell
May 2, 2006 09:15 PM
