Transmission Fluid Questions..
Old May 9, 2013 | 11:07 PM
  #21
piv15's Avatar
I checked my transmission fluid again tonight. It doesn't smell that bad. The only way I can describe it is like rain water on cement smell. I'm not sure if you know of the smell I'm talking about, but I assume it isn't bad. I felt it. It didn't feel gritty. It still felt smooth and not sticky.
Old May 9, 2013 | 11:56 PM
  #22
analogies's Avatar
I bought the IPDUSA.COM transmission flush kit and it worked fine....all you get is that hose with the right fittings....and some instructions. The fittings is what you really are buying...and it makes the job so much easier...and less spills...
but the vinyl hose that would fit snug on the fluid line would work...there is no insane psi on the line at idle...
a funnel with a vinyl tube and a twist on/off handle worked great for me...
Old May 19, 2013 | 12:47 PM
  #23
hvolvo's Avatar
I read that you can use dexron III fluid for automatic trannys is atf the same tranny fluid? The tranny oil cooler line where exactly is that line? Left or right? Side?
Old May 19, 2013 | 01:43 PM
  #24
ATF is automatic transmission fluid, yeah, same thing. dexron III is the right type of ATF for these gearboxes.
the transmission cooler lines are on the right side of the radiator, they are thinner lines, like 3/4" or something, instead of the fatter coolant lines.
Old Jun 21, 2021 | 03:08 AM
  #25
Charlotte Morgan's Avatar
One of the major problem is to control the transmission fluid. Whenever you face problem in your car's transmission, must reach out to best automatic transmission repair shop. They will guide you how to check and change the fluid.
Old Jun 21, 2021 | 09:56 AM
  #26
lev's Avatar
lev
I doubt they will give you a guide. No shop will do that. They may change the fluid for you or advise you on some other procedure you may or may not need, that's what shops do. Sounds like someone is trying to drum up business... Besides, it's a 2013 post!
Old Jun 21, 2021 | 10:34 AM
  #27
silvermine's Avatar
lol i heard that the eagle trasmizzion shop has special waterfluid to go into my tranny.. for only 199.99 plus tax
MSW
2001-2013 model year V70
Jan 10, 2018 02:00 PM
T5pilot
Apr 22, 2015 12:40 PM
DontaviousJones
Apr 5, 2011 10:26 AM
shuv70
Dec 29, 2005 06:02 PM
novablue69
Dec 24, 2005 02:53 PM
