transmission takes long to shift
Old Mar 25, 2008 | 08:21 AM
SPANK's Avatar
Default transmission takes long to shift
1990,240dl transmission when cold will shift at 40mph shouldn't happen. can someone shed some light
thanks
Old Mar 26, 2008 | 02:51 PM
billofdurham's Avatar
Default RE: transmission takes long to shift
How long is it since the transmission fluid was changed? It should be changed every 20,000 miles.
Old Mar 29, 2008 | 01:37 AM
rene's Avatar
I had an north american car that shifted at a higher speed than normal. Found a crack in one of the vacuum hoses and that fixed it.
Old Mar 29, 2008 | 08:09 PM
SPANK's Avatar
thanks for the post. change the fluid recently with the strainer,but the car seems to shift ok when the temp guage reaches midway any reason why this will happen, and in second gear i'm having to shift to a lower gear to get the trans.to move on.
thanks for the help
Old Mar 30, 2008 | 01:28 AM
SPANK's Avatar
thanks, i'll check for leaks
Old Apr 2, 2008 | 03:28 PM
daver80's Avatar
SPANK- my 240 had a "hung up" shift down cable, and took a long time to shift out of low. check that, maybe lubricate too. Dave
Old Apr 3, 2008 | 02:49 AM
SPANK's Avatar
where exactly is the shift down cable, how do i drain all the trans.fluid out of the trans (torque convertor as well.dont want to damage engine by it taking toooo long to shift from 1st gear.
help any moresuggestions
Old Apr 4, 2008 | 11:41 AM
daver80's Avatar
spank- theres a large cylinder on the top that the throttle cable goes around. The shift down cable attaches to that cylinder andruns down to the tranny. Mine didnt need lubrication, it just got itself hooked on a clip or something.
http://volvo2.homestead.com/aw70.html
go to this link for a cool easy way to change your t fluid. Dave
Old Apr 5, 2008 | 08:21 AM
wvb's Avatar
wvb
[8D]Are you having the trouble between 3 & 4th .
I had my overdrive solinoid gunk up 1 time .
Fluid needed pumping as well .Gunked up torque converter .
WVB
EricNR
Jul 6, 2010 08:23 PM
m300slr
Nov 18, 2008 09:02 PM
robsb
May 24, 2008 02:36 PM
tedv
Jun 22, 2007 05:10 PM
