Unknown Leaking Coolant Pipe to the WaterPump
Old Jun 6, 2016 | 07:04 AM
MrBoston96's Avatar
Default Unknown Leaking Coolant Pipe to the WaterPump
I have a 1993 Volvo 940 Sedan, Non Turbo. It has 153,302 miles.
Leaking coolant from this red pipe. I just changed the waterpump so it can't be the waterpump. I was wondering if I can just get a new pipe or just put rtv on it and call it a day. If anyone need anymore info let me know what I need post.
Pictures are of another Volvo 940.
I will have pictures of my car up as soon as I get out of work today.
Old Jun 6, 2016 | 09:37 AM
lev's Avatar
lev
I couldn't see the pictures but from experience this pipe is often hard to seal to the water pump's housing, causing a leak. The pipe is a pipe, unless it's rusted through (rarely), it is pretty straight forward. I don't recommend any sealants for this, better redo the water pump making sure the O ring that the pipe goes into is correctly seated. Sorry, I hate redoing things too but the cooling system is one thing I don't like to take chances on...
Old Jun 7, 2016 | 04:05 PM
Nichals's Avatar
I just did the water pump gasket for my wife car last weekend
I noticed that the pipe was a bit rusty under the o-ring so I put RTV all around the o-ring and all is good.
Old Jun 7, 2016 | 04:43 PM
MrBoston96's Avatar
I just got some rtv and putting in on now. Hopefully it does the trick
Old Jun 7, 2016 | 11:12 PM
lev's Avatar
lev
Well, definitely not a recommended way to go, won't last long!
I take a lot of chances and know all the short cuts and tricks but when it comes to cooling systems I don't like to take chances.
Old Jun 9, 2016 | 01:37 PM
Nichals's Avatar
Agreed, thats why I put the water pump gasket RTV on there. I have never had a Form-A-Gasket fail on me. Plus thats how it was when I took it apart, as the pump was leaking from the paper gasket part but both rubber gaskets were tight, although cracked and dry rotted still sealed.
fredbyte
Aug 18, 2014 06:22 PM
fredbyte
Jun 18, 2014 01:19 AM
nharms
Penta
Apr 21, 2011 03:15 AM
plopswagon
Nov 1, 2006 10:35 PM
plopswagon
Oct 31, 2006 12:41 PM
