Well I think we figured out what was going on with my Volvo but
Old Mar 14, 2018 | 05:12 PM
Suzanne4's Avatar
Default Well I think we figured out what was going on with my Volvo but
Hello I would like to ask a question about my 1985 240 5speed wagon. When we're driving on the freeway it seems that the car is is shaking. I can't feel it when we're going slow. We are having trouble with it staying started. We replaced the fuel pump and checked the injectors it starts and runs for a little bit then dies.
Oh and I would like to thank everyone who helped me and continues to.
Old Mar 15, 2018 | 10:53 AM
firebirdparts's Avatar
The shaking will probably turn out to be a tire.
Old Mar 15, 2018 | 11:40 AM
Suzanne4's Avatar
Default Tire and problem keeping car started
Usually when your it's a tire when you go faster it doesn't shimmy much ( you can't feel it). This the faster you go the more you feel it.
Now the other problem with it is it will start but it keeps dying. It runs for a little bit but dies. I have a 1985 240 5 speed wagon.
Old Mar 15, 2018 | 07:54 PM
running a bit and dying sounds like a fuel starvation issue. that could be caused by fuel in the tank or something getting into the pump pick up, clogged fuel filter, bad/weak fuel pump relay (not sure if your set up has an injector relay). How does it rev and idle when it first starts?
Old Mar 16, 2018 | 12:44 PM
TnBob's Avatar
Check the bypass check valve by your under the car fuel pump
shirley
Aug 22, 2012 07:12 PM
MC92
Dec 30, 2010 09:47 AM
Royalty
May 16, 2008 06:45 PM
gordon368
Apr 3, 2008 12:34 AM
Moparman
Oct 27, 2005 12:57 AM
