1994 960 AC Problems
Is it you don't get much air flow at all through the vents? That was the problem with mine it was the vacuum motor under the dash, which meant i really only got air on the windshield. Other things it could be is a bad compressor, bad expansion valve, or a bad clutch on the compressor (would keep it from compressing the coolant which causes it to become cool)
