Interminable 960 Engine Vibration . . .
Old Nov 14, 2015 | 04:01 PM
  #21
Cubic_Curiosity's Avatar
Bust! Didn't work. Back to the supplier on their dime...
Round 2, coming up
Old Nov 16, 2015 | 06:04 PM
  #22
jands's Avatar
well hope the next one does!!!
Old Nov 28, 2015 | 06:05 PM
  #23
Back again.
MAFwise, in the end no less than three different aftermarket variants didn't work:
START - COUGH - HUNT - SURGE - DIE
Restart; same result.
Clear all codes; same result.
Disconnect/reconnect battery; same result.
Original Bosch, still lumping along...
So, here's what finally DID work:
...in conjunction with this:
Interminable 960 Engine Vibration . . .-526-926175-qtips_productpack_500.png
...and this:
After about 45 minutes of directly and CAREFULLY rubbing the intractable, baked-in crud on the Pt wire surface with tiny amounts of Q-Tipped lapping compound, the wire was acceptably clean. Still a small amount of surface discoloration, but that was all: The offending coating was gone.
Rinsed thoroughly with a firm, directed stream of rubbing alcohol.
NOTE: The hot-wire aftermarket products probably can't be cleaned in this manner; as the wire element is filament-thin and quite brittle!
Reinstall:
START - SPUTTER - HUNT - SURGE - HUNT - SPUTTER - HUNT ... SETTLE.
50 to 70% of the butt-massage factor gone; and a few more beans found in the exchange. Sent all of the aftermarket units back for someone else's enjoyment
NOW, what evidently happened here is the aftermarket units present a baseline signal level to this ECU which is simply too far akilter for the stock algorithm to acquire and map. The old Bosch unit, when cleaned, seems to have demonstrated the correct response scenario; with loop closure as the endpoint.
DONE.
For the rest, I'll probably be turning some attention the the injector set next: Might've gobbled some bad gas at some point along the way. After that, we'll see what shakes and rattles from there
As A. A. Milne would say,
Bisy
Backson.
C. R.
(Cheers)
Last edited by Cubic_Curiosity; Nov 30, 2015 at 01:13 PM. Reason: Usual touch-ups ;)
Old Nov 30, 2015 | 06:32 PM
  #24
jands's Avatar
happy that you got it working....i was wondering if you were going to have the same issues with the aftermarket as i did.
Old Nov 30, 2015 | 07:14 PM
  #25
@jands:
Yessir; and the suppliers just seem to have never heard of the issue. I guess this makes it a confirmed problem in both OBDI & OBDII...
Must be a lucrative proposition to issue those refunds
Old Nov 30, 2015 | 07:31 PM
  #26
jands's Avatar
i dont know why this issue would even exist in a part being made lol. my company i ordered my aftermarket is the company that told me i might have an issue with it.
ocean238
Apr 17, 2008 06:20 PM
rvinson01
Aug 4, 2007 09:19 PM
maxx4072
May 18, 2007 07:03 PM
ohskigod
Oct 23, 2006 11:15 PM
YUKON
Sep 22, 2006 08:40 PM
