850 glt non turbo
Old Feb 22, 2012 | 06:55 PM
bgwalt37's Avatar
Default 850 glt non turbo
I have a 95 850 glt non turbo 2.4 and I keep getting a misfire code on cylinders 3 and 4 and random multiple misfire and multiple misfires po300 and po310. I have replaced rotor cap and wires and plugs I've cleand the EGR valve also cleaned the idle air control valve and I still get the same codes and a rough idle but runs fine after about 1500 rpm. can anyone help? any suggestions would be appreciated thanks. Brian
Old Feb 22, 2012 | 07:08 PM
Hi Brian, welcome to the site.
Have you checked your fuel pressure? Also, how many miles do you have on the car?
Old Feb 22, 2012 | 07:15 PM
Turkey_Sandwich's Avatar
Need to check compression.
Old Feb 22, 2012 | 07:29 PM
bgwalt37's Avatar
I think it has 200,00 and no I havent checked my fuel pressure
Old Feb 22, 2012 | 07:30 PM
bgwalt37's Avatar
I have heard the compression I guess I will do that I have a feeling thats what it is
Old Feb 22, 2012 | 07:32 PM
bgwalt37's Avatar
what should the compression be on at a minimum on each cylinder?
Old Feb 22, 2012 | 08:01 PM
For NA 5 cylinders, 1.3 - 1.5 MPA which is about 188 PSI - 217 PSI.
Test should be performed on warm engine with all plugs pulled and at wide open throttle. When I check mine, I pull the fuel pump fuse with it idling to bleed off pressure, and unclip the harness from the coil so there is no spark. I don't like fires.
For future reference, 2.3 turbo motor compression is 1.1 - 1.3 MPA or about 160 - 188 PSI.
Old Feb 22, 2012 | 08:05 PM
bgwalt37's Avatar
thanks I will try that tomorrow
Ablorx
Jul 4, 2014 08:33 PM
cjklipp0321
May 23, 2011 11:21 PM
squiz
May 12, 2010 03:27 PM
eddiecortes112683
Feb 22, 2009 08:37 AM
rfa1972
Apr 19, 2007 03:36 AM
