850R sticking caliper again.
Old Jun 18, 2019 | 05:20 AM
860ARE's Avatar
Default 850R sticking caliper again.
Hey all. My 850R passengers caliper sticking again. Its new aswell as pads and disc. When I take out pads the pistons do open again with force.im assuming the brake hose is junk.. anyone ever changed these before??
Old Jun 18, 2019 | 10:39 AM
time to do the hoses and a fluid flush. You may also have an issue with the ABS valves too. Its also possible the caliper is faulty - was it new or rebuilt? hoses shouldn't be a problem as they just unscrew from the hard lines - but make sure you have a proper set of tools and spray the end to the hard line with PB Blaster a few days before the job. Have you also inspected the emergency brake shoes?
Old Jun 18, 2019 | 11:22 AM
860ARE's Avatar
Emergency brake shoes arent in there. Second rebuilt caliper from local parts store. ATE brand... ABS is always a problem with my car. Could that cause it? What if i pull both Abs fuses think that make difference
Costy
Mar 10, 2012 08:56 PM
ddub
Apr 15, 2009 10:34 AM
JohnTheodore
Apr 28, 2008 12:35 PM
atownpdx
Dec 1, 2007 09:42 PM
tomservo
Nov 6, 2005 01:30 PM
