93 850 cam seal
Old Mar 24, 2011 | 03:24 PM
scottvickers's Avatar
Default 93 850 cam seal
i need to change the exhaust cam seal and will also do the intake while i am at it. i am wondering do i need to lock the back of the cams or can i just mark there position with a paint pen. i guess what i am wondering is will the cams just start moving or is it safe to just mark them
Old Mar 24, 2011 | 09:37 PM
Are you going to do the front or rear? If you are doing the rear the cams will be held in place by the t-belt. If you are doing the front, you will need to pull the t-belt and all that stuff so you will want to mark a lot and mark clearly.
Did you see my write up on that?
Old Mar 24, 2011 | 10:29 PM
ibified's Avatar
The way I have always done it is to put three marks on the timing belt where it touches the exhaust cam, and corresponding 3 marks on the exhaust cam itself so that they line up. On the intake cam, I put 2 dots in the same manner.
Old Mar 25, 2011 | 07:20 AM
thanks guys. i have seen pics of all these ways to hold the cams and it seemed a little overboard. i have a paint pen i will use you suggestions thank you
sporky
Apr 7, 2011 08:10 AM
cedarjames
May 19, 2009 07:45 PM
ricardonz
Jun 10, 2008 09:31 AM
sameyeham
Feb 18, 2008 05:29 PM
Red XC
Dec 3, 2005 12:08 AM
