96 850 No AC/HEAT or anything
Old Mar 21, 2011 | 12:12 AM
CoryJNason's Avatar
Default 96 850 No AC/HEAT or anything
The fan doesnt kick on, nothing. No heat, even when I turn everything on nothing happens. I checked fuses. What else could it be? I cant even get the defrost to work. HEEELLLLPPP!!!
Old Mar 21, 2011 | 12:36 AM
MattyXXL's Avatar
Ok so you problem is your fan doesnt turn on?
You said defrost, did you mean the windshield defog?
If you did mean defog, It sounds like your blower motor.. easy fix...
Old Mar 21, 2011 | 12:50 AM
CoryJNason's Avatar
My problem is I am trying to get the AC/Heat to turn on. Does that mean I need to start with the fan? If so how is it an easy fix?
Old Mar 22, 2011 | 10:57 AM
boxpin's Avatar
do you have a climate control system or manual?
Old Mar 22, 2011 | 11:30 AM
MattyXXL's Avatar
Im having a hard time understanding what your talking about, your being to vague.
When you turn on the A/C does any air blow out of the vents on ANY of the fan settings?
Or if it does, is your problem that your a/c does not get cold and or when you turn it to heat does it not get hot?
Old Mar 23, 2011 | 12:49 PM
autoxray's Avatar
Cory
I have the same car, however it is a wagon and this happened to me 2 years ago. I went to a juck yard and bought one for $10. Make sure you have a manual on how to install, a bit tricky.
Most likely it is your blower motor resistor that went bad. I my case, no fan, however at freeway speeds you can feel a low heat coming out of the vents. If this is your symptons, then I would think this is the culprit.
Here is a link for the part from FCP Groton.
1996-1997 Volvo 850 Turbo Blower Motor Resistor (for models with climate control)
Good luck and let us know if this is your issue.
Ray
Old Apr 1, 2011 | 11:19 PM
CoryJNason's Avatar
Anyway of telling if mine is bad or not? I would hate to spend the money just to find out it's not bad. Like if a previous owner replaced it.
Old Apr 2, 2011 | 10:51 AM
autoxray's Avatar
Cory,
It was Dec 2008 when mine gave up the ghost. Check out this link and then follow the instructions and you will be able to determine if it is your blower or the resistor.
https://volvoforums.com/forum/volvo-...-coming-25977/
I just bought another resistor from my local volvo junk yard for $45. I am installing it today.
Old Apr 4, 2011 | 02:20 PM
CoryJNason's Avatar
So today I decided to take out the blower motor to see if it spins. And come to find out someone cut the ground wire to it. So i rewired and WALA! It works again! But now it only works on high and and doesnt change settings or temperature. It has manual temperature control.
RED MOFO
Dec 28, 2008 08:13 AM
jmc00v70
Jul 6, 2006 01:50 AM
jaitken
Dec 5, 2005 11:51 PM
KMac
Jun 27, 2005 07:11 PM
